Can you provide the radio patterns for the antennas inside AP One AC Mini and AP One Enterprise so we can predict coverage with design tools such as ekahaw? Or can Peplink get in touch directly with ekahau to include these APs inside their catalogs? We also need to know the maximum output power per radio.
Thanks! This should be good for now, however I am a bit confused why one pattern is in dBi (gain-isotropic) and the other pattern is in dB (power)… is the enterprise chart based on the maximum output power? the best should be having the maximum output power of the radios and the antenna pattern with dBi reference so we can calculate a link budget while doing wifi planning.
