Curious.
I purchased some Cat-12 Transit Duos in December that cam with 2.5TB SFC Quota
The Transit Pros Dual Cat-12 Global I purchased a couple months ago only come with 1 TB
Shouldn’t these match?
Respectfully,
-Kevin
Curious.
Respectfully,
-Kevin
@kevinp, according to this table, the Transit Duo should be bundled with 1TB SFC quota, while the 2.5TB SFC quota is associated with higher-end models.
If there are discrepancies with the units, maybe you can submit a ticket for the team to investigate.
Thank you Wei.
Appreciate the clarification.
-Kevin
