I’m about set on buying a Balance20x for my home network but wanted to check a few details before I commit.
Can I prevent certain devices from using SpeedFusion cloud? Specifically a smart tv.
Do you receive alerts when on cellular?
Is it easy to turn on/off the SpeedFusion feature entirely? It would seriously reduce my bandwidth (my main ISP is 400/30) and I only want the “unbreaksble internet” when on important video calls.
Yes, you might need to build a custom outbound policy to do that but its a drag and drop process. ie send all traffic via SpeedFusion Cloud as the default, then above that a rule that identifies traffic from the smart TV by using its MAC address and pick a load balancing algorithm for it.
I would recommend the router utility app for that otherwise you can set email notifications up also.
Yes. You could just send zoom and teams traffic via SF and send everything else out direct. Take a look at Peters video here which also shows custom outbound policy setup too.
These types of traffic are already encrypted by a software vpn (Cisco AnyConnect) installed on my work computer, which I believe means the router can’t recognize them as separate services. Do you think the router could recognize this vpn traffic overall though?
Is it easy to just quickly turn off/on the SpeedFusion? The nature of my primary internet connection is that it’s rock solid for weeks on end, but then at random it will be less reliable for a few days at a time. Of course those days are always when I have an important meeting!
Yes I do. Although I am hoping my employer establishes a more nuanced system eventually, this is how it works now. The first thing I do when I turn the computer on is connect to the vpn.
