Question regarding BYO ESIM
Hi Peplink Brain Trust,
I have recently swapped out a physical SIM for a BYO ESIM for my Max Transit Duo and it’s working great. However, I can only access this ESIM from Celluar 1. I had the understanding that any ESIM profiles could be shared between the dual modems. If I’ve already registered the ESIM onto Celluar 1, how do I then copy that same profile to Celluar 2 as a back up? Obviously I’m not intending on using the same profile on each modem at the same time, but this will be useful when I’m moving between different areas and don’t want to swap physical SIMs around between modems.
The esim is tied to a specific modem imei. It is not movable except getting it reassigned by the carrier.
