Hi Everyone,
New to Peplink. Just want to know… does the rated VPN Throughout on the datasheet refer to the max VPN Throughput per peer or is it the total VPN Throughput of all the peers combined?
Thanks!
Hi Everyone,
Thanks!
The numbers quoted are the aggregate capacity for a given platform.
With PepVPN also consider the numbers quoted with and without encryption enabled - it can be quite an overhead on some appliances.
Hi Will,
Got it, thanks for the reply
