The image below shows the current outbound sessions display from Firmware 6.3.3. The first two sessions are both to port 443. In the SERVICE column, one says “HTTPS/SSL” and the other says “HTTPS”. Why the difference? Thank you.
I assume that the one with SSL is the first session to that server where the cert exchange occurred. The others are using an existing cert from previous connections. This is just a guess though.
