Quick question on gateway clustering: differentiate the gateway.
Client and Crew do not need to use FBB to access internet.
In case vessel start FBB to check email when VSAT is blank spot.
we allow Client to use Cellular when vessel is on cellular coverage by changing priority.
Gateway Grouping
Group 1; P1-FBB; P2-Cellular; P3VSAT
Group 2; P1-Cellular; P2-VSAT
Corp Network Group 1
Crew Network Group 2
Anyone has any idea on this?
No sure what FBB is, but if you separate the two groups of users / devices into their own vlans, you can have two priority based outbound policies (one for each group) to achieve what you want.
FleetBroadband is maritime satellite internet, telephony, SMS texting, and ISDN network for ocean-going vessels using portable domed terminal antennas.
These antennas, and corresponding indoor controllers, are used to connect phones and laptop computers from sailing vessels to the Internet. All antennas require line-of-sight (LOS) to one of three geosynchronous orbit satellites, thus allowing the terminal to be used on land as well.
The FleetBroadband network was developed by Inmarsat and is co...
Apologies on not explaining FBB.
