Dear, it’s possible mount the gregorian antenna wifi on the device AP PRO DUO ?
Is there any limitation in addition to the physical connection?
thanks
Antonio
thanks
Antonio
The AP Pro series uses N-Female connectors, so you can use whatever antenna you like as long as you mate it up properly.
the AP Pro Duo is possible configure mesh netowrk?
You could use the WDS feature to wirelessly extend the network.
