Hi Team,
We have a potential client asking if there is a way to integrate QR Code scanning with Captive Portal. Is it possible to add a feature that once you scan a QR code, the WiFi connection opens and they will be redirected to the Captive Portal?
Regards,
Josephine
Hi Josephine,
you can use any QR code gerator which supports WiFi Codes.
By Googling I found this one, but I haven’t tried it yet.
But please beware, that the website might get your WiFi Access credentials, so please be careful to only use trusted software or Websites.
Kind regards
Johannes
