QOS/Throttle of Speed per VLAN
I would like to request for a feature to limit the amount of internet speed per VLAN for more groups:
Please increase the number of groups which we can allocate the speed.
Thanks.
That speed is the max speed that would be allow from the vlan by all the devices.
Thanks.
You can do that, no problem.
When logged in to the device, click advanced, then in the left menu under QoS choose User Groups. Create the two groups here, with the Ip ranges each vlan uses. Save.
Then choose bandwidth control, Group Bandwidth Reservation and choose those groups and specify the limits you want. save & apply.
Bryn,
Thanks for the advice but it only allows 3 groups.
I have more vlans.
Thanks.
what software are you on? you can add up to 10 groups (or is it 10+ the original three? dont remember) on firmware i think 8.4.1 and above.
EDIT: sorry, I may have misunderstood. are you meaning that the sliders won’t show more than three groups? if so, i don’t think you can add more there.
They increase it to 10 in user groups at 8.4.0.
" Increased QoS User Groups to 10 and updated the Content Blocking page to support 10 User Groups for the Exempted User Group Table "
Hi…
You are correct… Peplink need to grow Group Bandwidth Reservation to ten, also.
lol i was close! i didn’t even google it :slight_smile:
+1
Either increase Group Bandwidth Reservation to 10 groups or, at a minimum, include the ability to limit bandwidth per VLAN for individual WANs. This has been requested in various forms for over 10 years now…
