hello
i was trying to set the bandwid limit to 10mbps but the connections accelerate up to 30mbps or my configuration is wrong?
thanks
![Untitled3](https://forum-media-cdn.peplink.com/original/3X/f/4/f4edb07f4c3f2d8e0cd3d110170e6b28f7e2ace5.png)
hello
thanks
May I know which firmware version you are using now?
Have you verify and confirm those usage more than 10Mbps is from Vlan 70 only?
hello sir
my pep version is 8.0.0 just upgrade this morning yes it vlan 70 i saw it in real time graph the bandwith exceed more than 10mbps but i will try to monitor now since the fm upgraded already
thanks
Please continue monitor from 8.0.0. Fyi, we have a bug in the old firmware and it has been fixed in 7.1.0 and above.
I don’t think it is possible to verify the source of the usage is from Vlan 70 based on the real-time graph (Status > Real-Time). Please verify at Status > Active Sessions > Search. I believe the usage in WAN2 is a mixture from the rest of the Vlans based on your configuration.
