Often times the 3G/4G does not operate at peak speeds… I’m not sure how or when the user group bandwidth controls kick in… does it go by what speed you configure the wan link to be? In many cases the speed for the 3G/4G modem rarely reaches it’s max speed so would this mean that the bandwidth control really never kicks in because the 3G modem never (or rarely) reaches the speed it’s capable of (or programmed into the wan link configuration)? If the link speed which is set when configuring the wan link controls when bandwidth control kicks in then can it be lower than the actual bandwidth to allow it to kick in sooner… or will the router not allow speeds over the stated speeds when configuring the wan link. Because of the intermittent speeds of radio communications I’m wondering if this bandwidth control system is built to deal with those issues. If someone could explain further how this actually works I’d appreciate it… but I’m wondering if VSAT & 3G/4G how well this really works. Thanks in advance, Sean
