I would like to prioritize my VoIP calls over SIP using my Balance 20.
I have setup Application based QOS on the Balance 20 and selected VoIP as the application.
My question is: Will this work and still prioritize my VoIP calls since I connect to/from my SIP server (which is out on the internet) using non standard SIP ports?
For example, I do not use 5060 as a source or destination port for my phones. Should I still expect the Balance 20 to prioritize my calls?
I ask because I don’t know how the Balance 20 does QOS, is it by TCP/IP port or something else?
Thanks in advance for any help you can provide.
