I am using 4 peplink routers (30,310,380,Max) to do high bitrate videostreaming. For that I create a speedfusion VPN between these devices.
I am using UDP/RTP streaming to a specific IP address on a specific port.
I noticed the importance of adding a QoS rule in all devices. However, it is unclear if I need to put the priority on the UDP stream or on de VPN stream. What should be the first priority ? Is the content of de VPN packets analysed and thus prioritised ?
Is I put priority on both I get every x-seconds a peak in used bandwidth and drops on the videofeed.
Hope the question wan’t asked before.
Arne
