I’m in stalled a puma-221 Combo LTE/WiFi/GPS Antenna to my pepwave max transit. Works good.
Question : Can I connect up the cellular antennas of the PUMA 221 to a different device and connect the wifi antennas to the pepwave Max. in other word do you need to connect all the antennas to the same device?
Hi. That is not a problem. The antenna does not care.
Thanks, I was hoping for that answer
