Is there a way to pull realtime gps locations from multiple MAX BR1 Pros into an interactive dashboard or some kind of real time location based updates? Is there an API for this or something similar? We are also playing around with the idea of geo fencing to allow alerts when a unit is moved. Any insight on this would be greatly appreciated.
Hi Jacob, glad to see that you are a partner that goes through FrontierUS
You have a couple options here; there is the GPS forwarding feature on the Advanced page under Misc. Settings. This will allow you to forward the real-time data to a server/application in either NMEA or TAIP format.
There is also a very robust API for InControl that you can use for this.
