We have configured 3 MAX BR1 Mini LTE’s on Verizon with static (public) IP addresses. Our application allows users of our system to point a browser to this address and access our telematics device’s user interface (great feature for supervisors and managers). On two of the three PepWaves this works correctly, but a third router tries to drop the user into http://192.168.50.1/cgi-bin/MANGA/index.cgi! We have enabled IP pass through and turned off DHCP (via an untagged LAN). I have been through all the config screens on all 3 MAX BR1’s, but can’t seem to find a difference. Can anyone help with this issue? Thanks!
Jeff Edelstein
AmeriTrak Fleet Solutions, LLC (AmeriTrak)
[email protected]
612-310-1419
I’m guessing you are using IP passthrough on port 80 to get to a device connected to the BR1. In this case, you’ve likely got Web Admin Access set to LAN/WAN, and left the default port to 80. This would intercept any port 80 traffic. I’d suggest you disable WAN administration and use InControl 2 instead, or use another port for the web admin via the System tab, such as 8888. This would let port 80 connect to a device behind the Pep, and you could do x.x.x.x:8888 if you need to remotely hit the BR1 web interface over cellular.
Thanks to all who read this post, and thank you Keven for taking the time to respond to our question. We have indeed solved the problem, and the 3 PepWave routers are going in the field this afternoon.
