is it possible to create something like a point to point link between two surf on the go?
This would be the connection schema:
Internet –> LAN –> RJ45 –> surf_on_the_go_01 )) (( surf_on_the_go_02 –> RJ45 –> PC
I’m able to use internet if I connect in wi-fi to surf_on_the_go_01 set as wired, and I’m able to connect surf_on_the_go_02 (set as wifi) to surf_on_the_go_01, but I’m not able to use internet from the PC.
Do I need to use particular settings in IP configuration of the surf on the go?
Set SOTG connected to ISP as wired, and set SOTG connected to PC as Wi-Fi.
Then on PC SOTG, configure the wifi settings (essentially you will just be connecting to the other SOTG’s SSID).
NOTE: Ensure that both devices are in bridged mode as well.
Great! Thank you!
In the user manual I have there is nothing related to “Switch to router mode”.
I think if I don’t have in the SOTG menu I need to download the latest FW…
I’m waiting to receive the SOTGs and then I will provide the screenscot if I cannot find it in the MISC menu.
The final customer is asking me another question: the device will be connected to a CISCO switch and they’re asking if the SOTG can use IP ToS (Typer of Service) with IPP=3 (that is for voice control).
From the user manual I can see there is a “QoS Settings” menu in which I can use the priority as Voice. Does this configuration with priority voice correspond to IPP=3 or is it a completely different thing?
Hi, I need a clarification about that: in the datasheet of the SOTG it is written that supports 802.1x but you told me that it is not possible to use RADIUS in the SOTG.
Do you mean that I cannot RADIUS if the supplicant is the SOTG itself but only if it is for example a laptop connected using the wifi to the SOTG?
Could you please explain this point?
From what I know the RADIUS server checks that the information is correct using authentication schemes such as PAP, CHAP or EAP.
So, could you please confirm me I can use the RADIUS server to authenticate the SOTG?
The supplier of the RADIUDS server told me:
“Dynamic WEP technology is based on the combination of 802.1x technology and the Extensible Authentication Protocol (EAP).
Our RADIUS supports the following EAP portocol variants : EAP-TLS (certificate based) and EAP-TTLS (login/password based).”
Does the SOTG use one of these?
Moreover, has Peplink a priduct that can work as a RADIUS server that can work woth the SOTG?
