i have a max br1 pro 5g. It has 2 WiFi antennas on one side and 4 cellular antenna on the other side.
what is the proper orientation of antenna to maximize reception? All up, at an angle, or ?
\ | | / Or |||| or \\
for WiFi, I’m reading vertical is best, but lte/5g is vague.
thanks in advance
Vertical on all of them.
Others will say to put the cellular antennas at 45° opposites to give 90 degree separation, but a) its impossible using the included antennas b) is theoretical and I see no real world improvement in testing.
Thank you. I’ll run some tests of 45, 0, 0, -45 And 0,0,0,0. ||/ And ||||
