We are using the Max HD2 to aggregate bandwidth on ships and are having a bit of trouble with the buildt in modem.
It seems that after a while of connecting and disconnecting fine it gets to a state where it is unable to make a connection to the network even though I know it must have a good signal. If I then power cycle the Max it connects immediately just fine.
Is this a known fault?
Is there a way to get signal strength either via CLI command or SNMP?
br
mario;
