Hi guys,
I try to configure the BR1 to connect a camera but cannot access ethernet wan port from local see diagram below.
From the laptop you cannot acces webadmin and offcourse the camera behind it.
Is there a tutorial how to configure such setup ?
Regards.
Hi @Techfree,
Have you configured the Security of the BR1 Slim so that perhaps it isn’t available via WAN, or on a specific port? See below:-
You may need to browse to https://192.168.1.3 to access the BR1.
You may also need to create a route on the Modem b-box2 so that traffic routed to the 192.168.50.0/24 network is routed via 192.168.1.3 before you’ll be able to see the camera.
Steve
Do a screen capture of your port forwarding settings on the BR1 please for review.
Also try translating a non standard port ie 192.168.1.3:8080 to 192.168.50.10:80 and see if that works.
