Dear I have problems with the connection to remote computers pepwave MAX BR1, through Incontrol platform, please urgently need your help.
Whats the problem, what happens? What error messages do you see?
when trying to connect the message “trying to connect” appears, after that it finishes loading and the administration of the computer does not appear.
I just did a quick check. It seems outgoing TCP port 443 from the device to *.peplink.com is unroutable, blocked or intercepted. If you try to “nc” or “telnet” ra2-1.peplink.com, you should normally see an SSH greeting message like this:
$ telnet ra2-1.peplink.com 443
Trying 54.148.216.73...
Connected to ra2-1.peplink.com.
Escape character is '^]'.
SSH-2.0-OpenSSH_7.6p1 Ubuntu-4ubuntu0.3
But probably you don’t in your case.
