Hi, I have established a tunnel speedfusion balance between 210 and 380 balance.
The tunnel is working properly, the performance tests are successful and the two networks are connected, but the hosts of the two networks not ping with one another. What am I missing? Missing some routing rule? Balance 380 is not under nat while the balance 210 is behind firewall.
I would ensure that the applicable access rules have been created on the FW on the B210 side. Also, can you ping the LAN interface of either Balance? We may need a network diagram with IP’s to help better troubleshoot (Feel free to send to support.cgi).
Otherwise ensure that Windows FW isn’t blocking the pings as well.
All hosts on the network 192.168.5.0/24 not respond to pings, only the balancer responds.
The default gateway of the network 5.0 is not the balancer but a router MPLS that rotate networks 192.168.0.0/24 and 192.168.3.0/24. It should work normally!
