i set up a peplink580 load balancing for my wisp and i have problem with iptv. i have on nat(customers) a ip tv and it not play. before i buy the peplink i have a balancer tplink (LOL) and play excellent . eny suggestion for my problem? i think the problem is with rtp protocol… thanks for help…
How many WAN links you have?
Your connections as below?
IPTV --Wired–> Switch –> B580 –> Internet? -
Have you configure Vlan on B580 and switch (If my assumption on item 2 is correct)?
IPTV able to grab IP?
Where you trying to access from IPTV?
man… i have 4 wan. no i dont have vlan.yes is grab ip. i tell you the tplink balancer with the same configuration work very nice. the iptv work with vpn from germany. i put internet–> B580 —> iptv and dosent work…i think the peplink is cutting the rtp protocol.
I think the problem is related to your settings. Please add oubound rule (Network > Outbound Policy > Add Rule) below:-
- Source: IP Address, <IPTV IP address>
- Destination: Any
- Protocol: Any
- Algorithm: Priority
- Priority Order: 1)WAN1 2)WAN2 3)WAN3 4)WAN4 <— These are example. You may put the priority order you want.
- Terminate Sessions on Link Recovery: Enable
Hope this help.
ok resolve my problem ! the problem is on wan the MTU ! THANKS
