Hi
I have a HD4 . I am trying to used it with 4 SIM card with the French provider SFR.
The problem I have is the Slot 2 of the HD4 it working well and the other slot is writing acquiring IP with out any result. Could someone help me about this issue
Rgds
I suggest getting help from your purchasing point. This could relate to the data plan, status of cellular connection, cellular antenna or SIM card and etc. Problem isolation is needed to determine which part is giving the problem.
Dear all. Have you find a solution ? I’ve the same problem.
