I have a brand new MAX Transit Cat 18 modem and I cannot connect to the cellular carrier. It has a 4-5 bar signal on both 3G and LTE but it is stuck in obtaining IP address. It is an AT&T 100GB data only plan for Hot Spots and Routers. The store has programmed 2 SIM cards and neither one worked. They assigned the IMEI to the second one. Currently have a ticket with AT&T and was wondering if there are any solutions from PEPLINK
First thing to check: Ensure the APN as assigned by AT&T is exactly correct.
Thanks Rick. It was not. The tech at TechnoRV identified the problem and changed to broadband. The default that came up in auto was fast.t-mobile.com. I questioned it while at the AT&T store put they justified by saying it must be using a T-Mobile tower to connect through.
Craig Faulkner
423-580-6033
