Hi, thanks for your help and time reading this.
We made some 5G connectivity test but visible connectivity is not achieved (it does not appear connected to the 5g network). Not so, with the other networks (3G, LTE) which work without problems.
Browsing speed is tested in different LTE networks which, although it showed good results, it was not possible to appreciate any available or attainable network of the 5G type. We tried 2 SIM providers, with the same result. Tests are carried out in different designated 5G coverage areas, all of which are unsuccessful when searching for a 5G network.
At the begginning we thought that real coverage is not the same as the one indicated by the provider, but in 1 case navigation results were obtained above 200 Mbps (5g is was to confirmed or concluded). For this reason, it would be appreciated to confirm:
- Whether or not the device should be connected to a 5g network (via Peplink connection manager)? Is there a 5G indicator in the software?
- What is the 5G network test method that you recommend us to use?
- How can we force the connection to 5G, using the 5G adapter connection manager?
Thanks in advance,
Marco Bravo
