How might one check/update the PRL on a BR1 MINI? A cursory check of IC2, the webUI, and product manual don’t hint at anything. Is there a way to check this via a CLI or anything else?
We have a customer that wants to remotely change this via IC2.
Any comments are appreciated.
Thanks for the response.
PRL is a Preferred Roaming List. It’s a list of cell carriers that the unit can connect to if it doesn’t find the one it wants.
Got it. You can’t set a preferred Roaming carrier order. You can restrict to a single carrier:
And you can restrict to specified bands and set allowed MCC country codes:
