Private 5G CBRS Outdoor network expererence?
I have a project with 20 IP cameras, and I would like to understand private 5g networks to see if it would be a solution here. I am looking at about 20 routers I would have to connect to the system. All are less than 2000 feet away from the 5G AP. Some routers will have LOC and others might have a tree in the way. I’m storing video at the edge, so I’m not going to be streaming 24/7 to record. >20 Mbps upload will work per router.
Anyone have experience here?
Hey Michael :slight_smile: It was good to see you at the summit!
I have significant experience with CBRS Neutral Host and Private Networks. Outdoors you’re permitted 47dBm EIRP which should cover your 2000ft distance with no issue, assuming flat. Trees/leaves and wet leaves will significantly affect transmission distance but 2000ft should still be no issue as long as there’s not a dense forest.
Let me know if you want to chat about specifics.
