To access N48 with your Peplink device, two requirements must be met.
- The cellular module needs to be updated to firmware 03.10.07.00 or above.
- The device needs to have been purchased in 2023 or later
**Updating your Cellular Firmware**
**Option 1 - Auto update via InControl 2** In your InControl organization page, go to Organization Settings > Device Management.
In the Device Management page, select all the device you’d like to update, and click on “Update cellular module firmware…” from the [Actions] drop-down list. Our system will then check all devices that are currently online and display applicable units for further action.
Option 2 - Manual update via [support.cgi]
You can access the support.cgi page, by replacing index.cgi with support.cgi in the url while you’re logged on to your Peplink device.
Go to Cellular module firmware update, click on “Check for update” and follow the on screen instructions.
FAQ:
1. Can I update the cellular firmware of my MAX Adapter/FlexModule/FlexModule Mini?
For MAX Adapters, FlexModules, and FlexModule Minis, connect/install it onto any Balance or MAX router, upgrade the router to fw8.3.0s052, then you should be able to perform module firmware upgrade via the [support.cgi] page.
Download links for the firmware 8.3.0s052 :
| Download Link | Product | Hardware Revision |
| Download10 | MAX BR1 Pro 5G | HW1 |
| MAX BR2 Pro | HW4 | |
| MAX HD1 Dome Pro | HW1 | |
| Download3 | Balance 2500 EC | HW1 |
| Balance 310 5G | HW1-2 | |
| Balance 310 Fiber 5G | HW1-2 | |
| Balance 310X | HW1-4 | |
| Balance 380X | HW1 | |
| Balance 580X | HW1 | |
| Balance Two | HW1 | |
| EPX | HW1 | |
| MAX HD2 MBX | HW1-4 | |
| MAX HD4 MBX | HW1-4 | |
| MAX MBX Mini | HW1 | |
| PDX | HW1-2 | |
| SDX | HW1-3 | |
| SDX Pro | HW1-2 | |
| Download6 | Balance 20X | HW1-3 |
| Download8 | Balance 210 | HW4-5 |
| Balance 30 LTE | HW3 | |
| Balance 30 Pro | HW1 | |
| Balance 310 | HW4 | |
| Balance One | HW1-3 | |
| Balance One Core | HW1 | |
| MAX 700 | HW3-4 | |
| MAX BR1 ENT | HW1-2 | |
| MAX HD2 | HW5-6 | |
| MAX HD2 Mini | HW1-4 | |
| MAX HD2 with MediaFast | HW1-4 | |
| MAX HD4 | HW1-5 | |
| MAX HD4 with MediaFast | HW1-4 | |
| MediaFast 200 | HW1,3 | |
| Download (USB Port)1 | Balance 1350 | HW2 |
| Balance 2500 | HW1 | |
| Balance 305 | HW2 | |
| Balance 380 | HW6 | |
| Balance 580 | HW2-3 | |
| Balance 710 | HW3 | |
| MediaFast 500 | HW1-2 | |
| MediaFast 750 | HW1 |
