Under QoS, is there a way to prioritize STUN traffic? I can see on the “active sessions” that the DPI is doing its job and it’s detecting the traffic as STUN, but is there a way to prioritize it?
I would appreciate any help on this matter.
Is this what you’re looking for?:
You can find it under Network or Advanced tab depending on your device and under QoS click application.
Hopefully this helps.
Kind regards,
Dylan van Elst
Frontier computer corp BV.
Thank you, I now know what I didn’t see it before. Blessings!
