Prioritize LTE-A over signal strength?
@Peplink is it possible for the device to look at all available bands in a given location and prioritize connection to bands which are providing LTE-A?
In some very rural places the device seems to prioritize signal strength and the device connects to a single band LTE (5 or 14) which is providing terrible data speed. And not LTE-A.
I then manually disable single bands 5 & 14 until it picks up on other lower signal strength bands which then connects at 3 bands LTE-A.
Is there a technical solution which does not require manual efforts?
Is there a way to give us users more visibility of all the bands and towers in an area and allow us to “click” a button and force the device to connect to some other bands or tower? We need that!
You can look at https://opencellid.org/.
The towers offer the band and bandwidth to the segment you are in off of a tower.
You could have a lower speed , but better consistency.
Your best bet is to Increase your cell gain with antenna or antenna max if possible or change another carrier.
