What is a Premium Deck Mount?
Peplink Premium Deck Mounts are rugged and heavy duty mounts are intended for deck and mast installations. This mount is made from the highest quality Marine Grade Stainless Steel to withstand harsh weather conditions and prevent corrosion at sea.
What Peplink product is compatible with the Premium Deck Mount?
HD1/2 Dome, Mobility Antenna, and Maritime Antenna are compatible with the Premium Deck Mount.
Is this Mount included in the standard package? If not, what shall I order?
How does it look like for a Peplink product with the Premium Deck Mount?
MAX HD1/2 Dome:
Mobility Antennas (except Mobility 42G):
Maritime Antennas:
