Dear, our customer for a project need to configure 300 Max BR1, he ask me if there is some tool for pre-staging the configuration in every BR1.
Do you have any tool for it compatible with the file format of configuration file ?
thanks
Antonio
thanks
Antonio
Hi Antonio, I would recommend to use the InControl2 cloud management platform for this. You can store configs in the cloud and push them down to all the BR1’s:
