hi,
I have had to reduce my budget on what devices i can use to bond/failover… and i got the following questions:
1)How durable and reliable are BPL-710? the reason i ask this is because i wouldnt be able to afford 2 of these to have them in HA… and if one can last me atleast 1year or 2 before i have to replace or get the second unit it would help out alot.
2)How hard would it be to upgrade from one model like the BPL-710 to the BPL-1350 ? Would i be able to copy over the configurations from one unit to the other ?
3)I am a little confused on the specs of the BPL-710 … on your site has 800Mbps and on amazon http://www.amazon.com/Peplink-BPL-710-Balance-710/dp/B002ZTNUC4/ref=sr_1_1?ie=UTF8&qid=1429427699&sr=8-1&keywords=BPL-710 its listed as 350Mbps … is that a misprint on Amazon site?
Regards,
Andre
