hi all,
I have made my mind on getting a 710 … looking at getting 3 connections from 1 isp (i will be getting 2 ip address per connection)for now… the other isp hasnt finished laying their new fibre cable in my area.
My question is since i will be offering an offsite backup … and i will be using SSL …
- an incoming request comes in, but the out stream from link 1 is maxed out… would the peplink box use link 2 for the upstream of that new request ?
2)Would it be possible to set one of the links up and down stream for server updates ?? for example all request coming from the network that needs to microsoft.com or to one one linux repository to be assigned to use link 3 ?
3)Is the throughput “1Gbs” up and down or just down ?
Regards,
Andre
