KPS
1
Hi!
I need to use external DSL-modems on the WAN-ports of the peplink-devices. For dialup, they use PPPoE.
Now, I need a possibility to assign an additional IP-Address on the interface to see debug-informations like:
- did the modem get sync?
- values like SNR
Is there any possibility to add a “debug-ip-config”?
Thank you
KPS
Are you looking at the PPPoE Management IP ?
KPS
3
Hi!
That looks great! Thank you.
Can I advertise this management-network via OSPF to be able to “remote-debug” the modem?
I had tested and the Management IP address will not advertise to remote devices via PepVPN/SpeedFusion.
KPS
5
Hi!
Thank you!!
One last question about this:
My DSL-modem needs VLAN-7 for PPPoE and VLAN-1 for management. Is this possible anyway?
Regards
KPS
The management IP traffics is untagged .
KPS
7
Hi!
I don’t think so. I tried to set VLAN to 7 to use the right VLAN for DSL, then, management-IP seems to use VLAN-7, too.
@KPS
Would you able to open a support ticket for me to check ?
https://contact.peplink.com/secure/create-support-ticket.html
P/S; Please ATTN the ticket to sitloongs
