Can MAX products (BR1, HD4, etc) be powered by the provided power supply and in the same time connected to an external battery as a backup solution?
Moshe
Are we getting an indication when there is mains failure or battery failure?
Moshe
Actually I just noticed on the HD4 MBX that you can see the status of the power sources… which is very cool.
Wish the BR1s had that status indication!
Me too! Would be great to see power consumption, temps, voltage detected, etc. Is there currently any way to see power consumption and temps on the BR1 series? Thanks
