Hi everyone, I’m looking for the idle voltage, active voltage and active current output the POTS adapter would provide.
It does not seem to list this level of detail on the data sheet. I have a phone that has different current and voltage requirements and may be stationed farther away from the unit. Trying to determine if it will fit my application.
Thank you!
Curious what the application is. While POTS voltages are relatively standard, there is variation (for example, off-hook and ring voltage), but these should have been accounted for in nearly every phone in existence many decades ago as nothing has really changed in this world.
What phone do you have?
POTS Adapter open loop is set to 25mA. If there is a need for certain application we can increase it, but it would come with POTS Adapter Firmware upgrade.
