POTS Adapter - max distance from POTS adapter telephone can be setup
What is maximum distance away from the POTS Adapter a telephone can be run? ( due to line loss)
Hey @Pineburgh , welcome to the forum :slight_smile: You’ll find this information (and a bunch more) in the specifications document for the POTS adapter (https://download.peplink.com/resources/peplink_pots_adapter_datasheet.pdf)
The loop length is 500ft per the specifications.
That being said, if you have good quality cable (24awg), 55Vrms should reasonably output 1000ft of capability. This is not me saying it will work, just that it might.
Thanks, I saw that but didn’t know what that meant! Thanks again.
