Hi there,
I have finally started testing my Peplink balance One!
One problem I am facing:
the router is assigned to LAN IP 192.168.1.254 /255.255.255.0, however one of the 3 WANs has DHCP set tin the same class 192.168.1.xxx; if this WAN is plugged in the router will not work. Is it possible that LAN/WAN must stay on separate class? If so, why?
Yes, the LAN subnet needs to be different then the WAN connections. Otherwise it will not be able to route correctly. I suggest using a different LAN subnet such as 192.168.100.x or something.
