Ports display on InControl
Did something change with InControl? There used to be a nice display of the device ports (green if something was connected). It was right above the map lower left.
This was a good troubleshooting tool for remote sites.
Thanks for any info.
Hi!
The physical interface section is still there, though it’s only supported by certain devices. It won’t be shown on unsupported or offline devices.
@Garth_Summey Let me loop in someone from peplink.
@Michael I believe the 20x support lan up/lan down events per port , is there any physical limitation to why it can’t support showing ethernet status per port on ic2?
Also is there a list of devices that are supported with ethernet status?
Just to be clear, it used to be there on all of our Balance 20s. I can’t put my finger on when it went away, the only major change we’ve made recently was implementing a VPN, I can’t imagine that would be the cause, but who knows?
Here are the models that support reporting port status:
B One
B One 5G
B One Plus
Balance 1350
Balance 210
Balance 2500
Balance 2500 EC
Balance 305
Balance 310
Balance 310 5G
Balance 310 Fiber 5G
Balance 310X
Balance 380
Balance 5000 EC
Balance 580
Balance 710
Balance One
Balance One Core
Balance Two
Dome Pro Duo
Dome Pro LR
MAX BR1 Pro
MAX BR1 Pro 5G
MAX BR1 Pro DX
MAX BR2 Pro
MAX BR2 Pro DX
MAX HD1
MAX HD1 Dome Pro
MAX HD2
MAX HD2 Dome Pro
MAX HD2 MBX
MAX HD2 MBX with MediaFast
MAX HD2 MediaFast
MAX HD4
MAX HD4 MBX
MAX HD4 MBX with MediaFast
MAX HD4 MediaFast
MAX MBX Mini
MAX Transit Duo Pro
MAX Transit Pro
MAX Transit Pro E
MediaFast 200
MediaFast 500
MediaFast 750
PDX
PDX EC
(Note: older h/w revisions may not support reporting port status.)
Well, I’m not sure what to say, here is a screenshot from when my Balance 20x used to display port information but now it doesn’t
