Portable casefor BR1 5G + antenna
Hello
I want to purchase (if for sale) or build (if not available for sale) a travel case for my recently acquired BR1 5G. Something like this
Questions:
1 ) Are you aware of any case for sale?
2) if not, which Peplink antenna do you recommend, and where to buy the accessories to build it into the case?
Thanks for your help!!!
That is a case from West networks. They have a BR1 Pro 5G case too:
Hello @pablofuente ,
Welcome to the forum.
Where are you based?
There are various distributors/resellers that have created cases, and depending where you are, you have options.
They also come in all kinds of flavours, single modem (BR1) dual (BR2) etc…
What makes them special is that they have a well fitted and adequate antenna in the lid, they have the SIM slots remoted into the face plate, come with battery packs and some other thoughtfull features, as well as properly fitted with respect to cooling.
You can ofcourse go your own way
get yourself a pelicase,
the peplink modem of your choice,
peplink has flat (slim) antennas as well as various accesories (Industrial Networking Accessories- Peplink)
and talk to your panelbeater to create you the right fitting faceplates to make it look good. And slot yourself a long weekend to make it all fit, as you have to remember, such cases get knocked about (not on purpose of course!!) and everything inside should stay in place.
Hello…
You can build a backpack, using MOB-40G, BR1PRO and huge battery inside it.
Hello @tgorter
I live in Florida and I own and BR1. I spoke to the West Networks guys and they are working on a new case (they had one, but it is not available anymore since Peli discontinued the case they use and they are searching for alternatives), but it will take a few weeks. Any US providers I can check? I am planning to add a Starlink Mini as well. Thanks for sharing!. I am horrible at DYI and patience…so I prefer to go the commercial route. Thanks!
yeah, I would have sent you over to @westnetworks as well, but if you have already spoken to them, then you are more up to date than me :slight_smile:
With luck some other resellers here will pipe up and give options!
We offer a custom, patented case that’s designed for BR1 Mini, BR1 Pro, and Transit Pro form factors that includes a battery and a custom antenna built into the lid (single-radome). We have this in-stock and ready to ship.
Feel free to DM me if interested.
