There is a port speed mismatch between LAN interface of MAX-br1 MINI and a router. I see 100Mbps/Full on the router. But I see 1000Mbps Full on MAX-BR1-MINI. I know BR1-MINI supports 100Mbps interfaces? How can 1000Mbps be possible?
I tried everything such as set port speed manual, auto for each of side etc.
Note: I can not ping from router to Pelink’s LAN and vice versa
firmware: 8.0.0 build 3455
What happens when you set the speed to 100Mbps full duplex and check advertise speed on the mini?
Hi Martin,
I tried all settings. Same result. LAN port is connected to wan0 of Silverpeak SD-WAN router. It seems 100Mbps/Full on Silverpeak. Also same result Firmware upgrade from 7.1 to 7.1.2, 8.0.
This can be display issue. Please open a support ticket for support team to check.
Thank you
Thanks sitloongs. I will open a ticket
