Configuration:
Peplink Balance 20 with port forwarding setup for port 80 on WAN1 to a private IP address. WAN1 is a public IP address acquired via DHCP from an AT&T Uverse gateway.
An Inbound Firewall Rule is set to allow port 80 traffic to the same private ip address. Logging is enabled.
Problem:
Unable to access port 80 from WAN1.
Question:
How do I view the log to see if the traffic is being allowed or blocked?
You will most likely need to subscribe to a static IP address from AT&T as most likely they block incoming port 80 with DHCP addresses.
You can create an inbound firewall rule to allow port 80 and then enable logging. If any port 80 traffic is hitting your WAN1 it will show up in the event log.
With firewall rule logging enabled you can see if the incoming connection is being allowed or denied under: Status> Event Log. Also make sure the Balance does not have port 80 open on the WAN.
Tim,
The gateway has 5 static IP addresses, the Balance 20 is receiving the first one via DHCP. The vendor says that the gateway is not blocking any traffic.
Ron,
In Status/Event Log I don’t see any events pertaining to port 80, either Allow or Deny, just WAN 1 connected and disconnected.
Edit: Also, port 80 is not open on the WAN
Thus, it appears that no port 80 traffic is reaching the firewall and that port 80 traffic is not reaching the Peplink.
Update: I still have not been able to get this working. I went ahead and setup another Balance 20 at my own office.
It does not work there either.
I have a support ticket in with Peplink and a technician looked at the production firewall but could not get it working either. I have sent messages asking for updates but haven’t heard back in a few days.
