hello
hello how to port forward in specific port like 161 because i have a subdomain redirect to my router public ip then forwarded to local cacti server.
thanks
hello
thanks
Do you think this will help ?
hello sir
yes im able to access from outside the web admin https://mypublicip:1122 without any prblem
thanks
hello sir
ignore this post i manage to make it work the cacti wont accept if i put port 161 because has a webserver /cacti
thanks
Yes, Port Forwarding should work as expected and usually the problem cause by duplicate services running on the same ports.
Good to heard that it’s work fine.
