Poor T-Mobile speeds
I put a sim in my new Balance 20X, because why not? I’m not expecting to need it, there’s already two broadband connections. However, the performance I’m getting is very disappointing, and looks suspiciously like it’s capped.
I’m using a T-mobile sim, with a “T-Mobile Unlimited Tablet TE”, which only costs $25/month. From that I get 0.5Mb/s down, with very little variation. That’s disappointing because my LTE iPhone sitting next to the Balance will get 20-25Mb/s down. (Though for upstream, it seems to do better, 6Mb/s vs 3Mb/s.)
The fact that it’s such a consistent speed makes me think there’s a cap somewhere. T-Mobile are more confusing than helpful when I look at their website. In small print under the plan, it says:
Video typically streams on smartphone/tablet at DVD quality (480p). Go 5G: During congestion, customers on this plan using >100GB/mo. may notice reduced speeds until next bill cycle due to data prioritization. Activate up to HD streaming on capable device, or video typically streams in SD. Up to 15GB high-speed tethering then unlimited on our network at max 3G speeds. Go5GPlus: Activate up to 4K UHD streaming on capable device, or video typically streams in SD. Up to 50GB high-speed tethering then unlimited on our network at max 3G speeds.
Personally I’d say DVD speeds are average 4Mb/s. It seems to hold out the hope of upgrading the line, in some manner, but nothing I click on gives me that option.
0.5Mb/s is just not useful, so I’ll be killing the line unless I can find something better. Any ideas?
You appear to be using a plan intended for tablets rather than routers/hotspots. You’re seeing the likely result. TMO has plans suitable for routers – it’s just that you do not have one.
I can’t find any suitable T-Mobile options, the only internet option they want to supply a “free” wifi router, not “bring your own”.
Three thoughts:
  1. Have you visited a TMO store with your router (or IMEI) in-hand? That has been a successful approach for some of our customers.
  2. I’ll mention that we have two T-Mobile test SIMs we acquired from this page – Prepaid Data Plans for Hotspots & Tablets | T-Mobile Prepaid . They work.
  3. If you can qualify for a business account there are more options. We have an unlimited TMO SIM for which we may a reasonable sum each month but the location of use must be vetted (only fixed locations where TMO has excess capacity.) You will not find this opportunity on-line.
I feel your frustration and join you in this. And, I’ll mention this is why we refuse to resell mobile data plans.
Thank you.
Those options didn’t show up in my account, and when I tried to select it, I got to “I already have an account”, log in, and it just went to the generic account page, where that was not an option.
I had to use the online chat, which I hate, but 49 mins later, I have a new sim winging it’s way to me.
I absolutely hate talking to customer disservice like that, I usually don’t have the spoons.
Could I ask what the “reasonable sum” is? This isn’t critical for me, and $20 month is about as much as it’s worth to me.
Also on the generic account page, the plan was listed as “BYOD-ROUTER, No Add-Ons”, which sounds like the right thing, but was then “T-Mobile Unlimited Tablet TE” when you click on the line.
We pay about $50/month
I’d like to tell you I’m surprised. ;<)
I got the new T-Mobile sim, with “Mobile Internet 5GB (TE)”. That gets 5G/moth for $25, either “mobile” or “hotspot”. I’ve been assuming the router counts as hotspot.
That’s getting speeds or around 10Mb/7Mb, which is reasonable.
At the same time, I also got a Mint Mobile sim, they’re offering $15/month for 3 months on any of their plans. I got the 20GB/month plan. It uses the T-Mobile network, so is getting much the same speeds. After the introductory period, it’s about the same price as T-Mobile, but you have to pay 3 months in advance, or it’s cheaper if you pay 12 months in advance. Then the 20GB/month would be $25.
I might also mention that AT&T has a similar pre-paid plan for moderate users. $300 for a year in advance. 20gB/month. One of our test SIMs is on this plan and it works well.
3 months later, I’ve decided to use the Mint Mobile plan, $360/year for 15GB/month.
I cancelled the T-Mobile sim.
I even did a test where I unplugged the Cabel and DSL, so it was only using cellular, and thanks to the Balance 20X, nothing noticed. (Apart from things were a bit slow at times.)
The culprit behind your slow speeds with the T-Mobile Unlimited Tablet TE plan is likely a combination of factors:
  • Tethering Throttling: This plan only offers up to 15GB of high-speed tethering. Since you’re using the SIM in a mobile hotspot device (Balance 20X), you’re likely exceeding that limit and experiencing throttled speeds (capped at 3G).
  • Plan Limitations: The plan itself mentions video streaming at DVD quality (480p), which suggests a speed around 2.5Mbps. You’re getting even less than that, possibly due to congestion or prioritization for other users.
Here are your options:
  1. Contact T-Mobile: They might be able to clarify the specific speed limitations for tethering on your plan. Inquire about any upgrade options for increased tethering data or higher speeds.
  2. Consider a different plan: T-Mobile offers mobile hotspot specific plans with higher data caps and potentially faster speeds. Look into their Go5G or Go5G Plus plans which offer 50GB and unlimited high-speed tethering respectively (though speeds might be throttled after the limit).
  3. Switch carriers: If T-Mobile doesn’t offer a suitable plan, explore options from other carriers. Look for hotspot data plans specifically designed for mobile hotspots with higher data caps and potentially faster speeds.
Since you already have two broadband connections, cancelling the T-Mobile line might be the best option if their plans don’t meet your needs. However, if you need occasional mobile data backup or internet access on the go, a different plan with a higher tethering data cap could be helpful.
I found a different solution to this, put a regular phone sim in the machine.
I happened to have a spare sim lying around, as T-Mobile gave me one free several years ago. I was surprised it worked, and then even more surprised when it counts it as phone data, not hotspot data. Even better, T-Mobile just gave me another free line, as compensation for raising their rates. That also works.
T-Mobile does seem a little confused, and thinks the B20x is a “Stylo™ 3 PLUS”, which is an LG phone. The second free sim is now in another B20x, and T-Mobile think that is a “iPad 7th gen - Space Gray - 32GB”.
(Coincidentally, the tablet sim I originally tried is now in my wife’s iPad, and she loves having connectivity anywhere, but doesn’t worry about the speed, but can get 10-30Mb/s as well.)
I also put a random cheap, data only eSim in one of the B20x units, to see what’s what, and that also works.
All these are getting download speeds in the 10-30Mb/s range, which is fine for what I need. I’ve seen upto 70Mb/s in a different device, by optimizing the device placement, to get a better signal from the local towers.
