Just plugged in my Ap One mini AC into a Trendnet Edgesmart poe switch. The POE ports are set to auto, and looking at the web admin, noticed it classified it as class 3 device, instead of class 1:
Hi. I am not at all familiar with that switch but I can tel you you will not damage a POE device by allowing it more power than it “wants” (draws.) To over-simplify a bit, the switch will determine supply voltage (V) but it will be the AP that determines the power (W) consumed and this is based on the amperage (I) required (P=IE for a simple DC circuit as is this).
