Hi Peplink!
We’d like a API call or a button in the web admin/incontrol to power cycle a PoE port on a router/switch. Would that be feasible?
Thanks!
Hi Peplink!
Thanks!
Sound like you wish to “reboot” the PoE port. May I know disabling/re-enabling the PoE or the port can achieve the requirement? Mind sharing the used case?
Thanks.
Hi TK,
Yep, we currently manually disable/re-enable PoE on the port but ideally would like to do this by API if the end device stops responding.
There is a device API for enable/disable PoE port for device with firmware 8.1.1 or later.
POST /api/cmd.port.poe.enable
POST /api/cmd.port.poe.disable
If you want to use the device API through InControl API, you may check this endpoint
POST /rest/o/{organization_id}/g/{group_id}/d/{device_id}/devapi/{api}
Does this work on the SD-Switch (they have different firmware)?
If so… could we get the ability to change the VLAN on a port by API?
Hi Bryn,
The PoE API does support SD switch devices.
There is no device API to update VLAN settings on a port, you may be able to use an Undocumented InControl API for that. Please send you request to [email protected] if you need it.
Thanks, I have sent a request through
