Would it be possible to add in the to be reviewed list the possibility to add or remove MCCMNC from the PLM list of cellular modems?
Even better if it could activate roaming too.
Makes sense as they already allow control of apn and user/pass. That would mean every parameter needed to establish a connection after powering the device for the first time or a full reset.
Enabling and disabling roaming settings should be fine for the the SMS use case. Engineering team still considering the commands that need to be use.
For the PLMN list, Engineering team still considering the use case whether SMS is safe to work on the PLMN list. Managing a list via the a SMS potential will cause other problem when invalid or PLMN value added and in the case that you have no WebAdmin access for the device.
Based on my understanding from your request, it’s more like “Carrier Selection” in case the device is not getting connection and you not able to access the device locally, you still can send a SMS command to set the roaming carrier that well known working for that area ?
For SMS control, it’s should be something simple instead of full list that you need to manage using the SMS. Carrier selection is more like a single PLMN code that you can define to configure the Cellular connection using the MNC/MCC defined. You can anytime to remove the settings if it’s not helping.
For PLMN list, assume you have defined 5 code for the list. Seen you have no way to access the device, how you going to verify which PLMN code defined ? It can be a risk here.
